ECU apps
evolvingGS-t
270
Feb 2, 2005
Sandy, Utah
Which ECU's will fit the 97gst? Besides of course the 97 and/or 95eprom. Are there any other years or ECU's that will fit.
A 97-99 will plug in and work without modification. The 95-96 ECU's will require splices to work properly since the CAS signal is inverted from the 97-99 4G63's. For the easiest application, simply replace it with a 97-99 and you'll be good to go. You can get around splicing with a 95-96 ECU in a 97-99 if you have DSM Link, or an EPROM Chip that will invert the signal (i.e. Keydiver or TMO).
Hope that helps,
Andy
