ECMlink Ecmlink v3 Dies putting into neutral
2GFWDbeast
1,094
15
Jan 17, 2010
kenosha, Wisconsin
how to tune for when thrown into neutral. Every time i put car into neutral to either slow down or after a wot pull. the rpms drop and car turns off.
ok thanks. How high should i raise the offset? Or should i just play with it until i get it right?
Goto the "ECUConfig" tab. The first tab that opens should be "RPM/TPS". "Coasting FC offset" is to the right of the window on the "RPM Controls" section of it. Try raising it by 200 RPMs.
There is a check box and menu for it under the RPM's tab. Try setting your Caost Fuel Cut rpm to the same RPM as your idle (or around 900 rpm and work from there)...
See my above post.
And to be correct, what ever your idle is, you subtracted 750 from it to get the rpm difference that would be inputted into the box.
well i raised it, and now it dont die when i rev it at idle. But it still dies when i get on it and throw it into neutral. I raised it to 500 and it still dies. But if i disabled the idle switch when moving, would that maybe stop the stalling?
Have you checked for boost leaks and are you recirrculating your BOV if you are not properly set up for venting (GM MAF or speed density).
im recirculating and i tested up to 30psi with no leaks.
