ECMlink ECMLink newbie
Ghost_92TSi
1,046
Aug 18, 2009
El Paso, Texas
Just going to post this here because the other section is picky. I just did a stock rebuild on my car:
I need to update my mods list but I added bushing this time around on the front subframe, SB SS-TZ clutch/pp. Using the GM 3" maf to ECU, FIC 750, and ECM link.
Been reading on ECMlink wiki as well as other post of here. I still need to re read through the WB to ECU hook up. I just wanted to start the car and see if I could at least move it around.
Just trialing and error right now, I did some adjustments to the MAF and I noticed that was better.
I did fix all my boost leaks prior to this, replaced injector seal, TB gasket, Tighten one coupler, and J-pipe gasket.
My o2 only cycles once or twice every now and then?
I also noticed it leaned out when I reved at the end.
If anyone notices anything I am missing: or better things to look at. lmk.
https://onedrive.live.com/redir?resid=C424F305E416766%21115
Guess they moved it here anyways. Base timing was anout 4 degrees a adjusted it closer after. Boost leak is good. Still going through the other list of requirements.
I was using an innovative wb and it was running really rich 10-11 at ldle. Changing the hertz down alot got me to 12-13. I changed to the stock mas and same thing so I can rule out the gm maf.
Yea I read through that when it was first posted. I used those to get where I am now. I think I am going try another o2 sensor. My fan stopped cycling as well so it got a little hot last night. After I fix that ill see where I am at.
My A/f is good in open loop now, no more stupid rich, in closed it runs lean 19-21. the o2 cycles when i hold it around 1-2% TPS although it revs up and down when i do that.
Enable narrow band O2 sim.
Kind of hard to do when he doesn't have a WB hooked up.
If its stuttering under acceleration, then adjust your Throttle tip-in under the direct access tab.
It's stuttering under acceleration because nothing is calibrated...not even basic airflow according to the second log. Changing the throttle tip-in at this point would just muddy the waters more.
OP -
1). Please attach your logs to your posts directly; not through a 3rd party file share
2). You need to go back to square one and get your fuel and airflow properly calibrated.
Start here:
http://www.dsmtuners.com/forums/ecm...efore-you-ask-ecmlink-dsmlink-log-advice.html
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
