AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
I've had this issue before and thought I fixed it but that's not the case.
The launch control is always active whether or not the clutch is depressed and it's also using that rpm as my rev limit. Speedo works in car and in link V3. Top clutch switch works but for some reason, there was 6 ohms of resistance on the black wire (to ground). So I cut the black wire and wired that to chassis ground. The green/black wire runs to pin 104. When I check clutchsw in link, it works as it should, 0 when depressed and 1 when off the clutch.
@steve Since launch control works without the clutch cut wire, what does ecmlink use to verify the clutch is depressed?
. I’d have to imagine that if speed in link is accurate, then it’s getting the proper signal.
