2G Clutch cut without Auto-cruise ECU
jw4free
147
76
Dec 3, 2008
Billerica, Massachusetts
1995 2G
I have deleted the auto- cruise ecu, connector B-29 and associated wiring.
I am wiring ecmlink clutch switch wiring to connector B-04 (normally open) in the black/red wire to pin 2. Black wire (pin 1) to ground thru B-08 remains wires per stock.
1. Does Black/red wire circuit require power from auto cruise ecu (which doesn’t exist) or
2. is pin 91 an ECM voltage ground that generates a signal on a closed switch?
Presumably the second scenario is correct. Am I ok leaving the short orange disconnected.
