eclipse gsx help
romeo dsm
Mar 8, 2019
chula vista, California
good day friend today mount my motor 6 bolt n / a
I put rods 1g piston 2g
acl oil pump cancel balancers
the problem is that when I lit it frame in the 100 oil gauge
after low to 60 and as soon as accelerated a little more than 100 passed the pressure after 1 hour shot blue smoke and it is not removed
everything got new
Oil pressure is too high, if you still have 60 psi at idle after one hour. The oil pressure relief valve on oil filter housing could be stuck.
Remove the oil pressure relief valve and clean the piston part and inside of sleeve to make it slide smoothly. And see if the oil pressure gets lower or not.
Your translation skills are amazing...
Agreed, it sounds like a stuck bypass.
