Eclipse 97
Barn Find project
Make sure you delete all of it correctly. The first few times I attempted this, I followed some poorly done instructions, had bad idle surging, and in the end, had to put it all back in. Now I know what all to pull and block off, so now things run just fine.
Any chance you know which ones are the correct ones? Shitake mushrooms everywhere?
Remove all vaccum lines except bov, wastegate, and fpr. Remove the charcoal canister and the egr valve. Block the egr ports on the intake manifold. Remove vac lines from the 2 solenoids directly behind the manifold attached to the firewall, but leave the electrical connections plugged in. There's a vent from your fuel tank going to the charcoal canister, zip tie it somewhere as it remains where it is.
Thanks Bud this is almost exactly what I have done so far! You rock and thank you for responding and the help!!
Got my Non cruise control cable yesterday be knocking that out this weekend and hopefully finishing up. Only thing I need to do is put back those two sensors you mentioned.
By chance anyone know the size and bolts required to put back the timing belts covers on the 2g 7 bolt ? Mine are missing ordered new covers have everything but bolts. Just wondering before I reached out to dealership. If there is a thread on this please let me know.
