chanley talon
- 773
- 14
- Nov 10, 2005
Spencer,
Indiana
Ok i just replaced my oil pump from ebay ......risk......... duh........ Anyhow it clicks? I also elminated the b/s why i was at it. Its seems my car is running about a half second slower to 60 mph Any how . Does anyone in here think its possible that this oil pump is causing phantom knock? Just wanna let you know timing marks are perfect and base engine timing is set accuratley at 5 degrees. I do have a logger but not sure what i need to look for.
I have also observerd that it has a slight studder if you put the throttle at a certain point . Basically barely pushing on it . I beleive that the isc motor is bad as well..
No boost leaks!!! spark plug gap is at 28
