ebay mbc
i was thinkin of getting one to... any specific reason why you wanna sell yours?
I have one of those...it works; however, let me tell you that the springs that they put in them (that they put in mine...should I say) can be too strong. I had to cut coils off the spring to allow the wastegate to open below 15psi. When I first put it in my boost was going up to 19psi before id shut it down...not good.
Does you'res do that dsm4life? That's what i'm nervous with on these. I want it to be fully adjustable from 3psi-25 or whatever.
Get a Joe P. That one is not worth it. I had it on my car for about 3 weeks. I dont like the fact that it bleeds vacuum off constantly and i was not able to boost above 15.
i bought one and I say that it's shit. it doesn't even hold boost, what I mean is it will boost to anything and will not peak at all.
pm me if you want it , i havent had a problem with it or i would tell you. Its 4.00 bucks man
Defiant said:
You'll never get down to 3psi. Lowest peak you can run without a different wastegate actuator is about 11.
ahh figured you could, ok cool. I'll let you know about the mbc dsm4life.
