2G Easy Way to disconnect Antenna?
Volkan-Eclipse
Nov 25, 2018
Kempten, Europe
Hello guys.. sorry if i'm posting in the wrong place i'm new here... so anyway since we are now in winter my Antenna refuses to come fully up which i expected i always thought about disconnecting it, my first guess was to disconnect it on the Head Unit well dumb me it Antenna still worked ouf course but without a signal..
can anyone please tell my where the right cable is? I've heard i need to take off all the panels in my hatch and it's somewhere there? maybe some of you got a guide for me i'm so thankfull for any help :)
also sorry for my bad english i hope you unterstand what i'm trying to say..
Greetings from Germany :)
Behind the panel on the driver's side in the hatch. You can just unplug the power motor for the antenna.
Thank you i will look into that! also any important things i should know about the Panel? like is it just all clips or are there some screws?
just asking as i don't want to break it apart haha
I can't say how it's held in with 100% certainty as the panels are different between the coupe and the Spyder (I have a Spyder..). The panels in the Spyder have a few screws that are very easily located with the spare tire cover out of the way and then the rest is just clips
Made a quick illustration to help guide you. First do the blue parts, then the red.
The center panel comes off first, you grab it at the bottom and pull out (towards the rear seats) until it pops out halfway. Then you put each hand on the top and pull upwards (be aware of the 4 metal clips falling out).
Then you unscrew the black net tab, the 2 screws on the shock cover, and the 2 screws on the bottom of the driver side panel (hidden under the wheel cover). It should just pull out after that.
Keep in mind these plastics are fairly sturdy so you wont really break them. The things that break most commonly are the white locators on the back of the center panel. Hope this helps.
Dude thank you so much! especially the tip with the center panel i still couldn't get that one off since that panel was sitiing so hard on but now atleast i know how to do it right thanks again!
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G 3rd Brake Light With Trim Panel & Hardware
    2G 3rd Brake Light With Trim Panel & Hardware $85 + shipping & paypal feesYou must be...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Manual Shifter Base with Short Shifter
    2G Manual Shifter Base with Short Shifter $75 + shipping & paypal feesYou must be registered...
