1G Easy Power? Cheap mods for power?
If the motor is fresh then you just need fuel and a way to tune things. The stock 14b is a fun turbo around 20-22psi. Quick spooler and holds solid to redline ;). You can find all kinds of used parts on this forum to make your car faster. Just make sure the seller is honest and really knows what there selling or even has it. And make sure to use PayPal just in case ;)
Once you can tune you would need some injectors 750-850's. A fuel pump rewired walbro 190 or 255. If you get link get the boost by gear option and a map sensor. A wideband that logs good and a boost Gauge really help. Wideband is a must the boost gauge can be seen thru link if you have a map sensor. But it's nice to have the gauge in front of you. Then once you do a boost leak test and have no leaks. Up the boost to 16-17 and tune then go to 20 and boost away.
I have a Greddy BOV, should I also get 3in or 2.5in intake piping? Would that make a HP difference?
Bone stock? If so, the absolute first thing I'd do is rewire your fuel pump & install a boost gauge, assuming that you've already taken care of everything maintenance-related. Then start modifying from there...
online references:
www.vfaq.com
www.plymouthlaser.com
This ^^^^
REWIRE immediately, install Walbro 190 (works with stock Fuel pressure regulator) or Walbro 255 (may or may not work with stock FPR), and get a boost controller. Pick up a cheap FMIC or get the VRSF kit (I have it and it's good).
My brother ran 13.0 @ 106 on crappy tires with this simple setup with his 1G, shouldn't cost you more than $500 or so. Everything else stock.
To echo those above...maintenance so you don't blow something up, instrumentation (wideband, boost) so you don't blow something up, Link...well so you don't blow something up.
All three make it way easier to figure out what is going on. It cost $$, but it is cheaper then a rebuild.
Best thing you can do to get reliable power? Get the easy/cheap bug out of your head. Now. It's lead to more broken DSMs and the death of the scene. It's not dead yet, but it's in its death pangs now partly because of so many people trying to get cheap/easy power. Maintenance as said before. Check the timing belt, all the hoses, water pump, all the really boring stuff like gaskets, alternator, etc. Check, double check, triple check everything. Seriously.
Once you've done that, grab yourself a K&N airfilter. Hack the aircan, hack the MAF sensor, do all the freemods. I'm not going to tell you what they are, you'll have to search and learn for yourself. Grab a MBC, rewire your fuel pump, throw on a GOOD turboback exhaust. Grab yourself a good boost gauge, turn the boost up to 16lbs. Once you've learned how to deal with that little bit of increased power, go from there. 16G, ECMLink, 750-850cc injectors, wideband, clutch. Do not...DO NOT get in a hurry and try to cheap out. You WILL regret it, the DSM will ABSOLUTELY leave you stranded and miserable, you will end up parting it out, crushing it, or continually trying to band-aid it together until you tear your hair out.
Best advice bar none: Get the word cheap out of your head. Even a good, solid 16G setup that is RELIABLE, will cost you. Granted not as much in comparison as a lot of other cars would, but it's not gonna be for pennies. Do it once, do it right.
Absolutely. I have owned my car since 2006 and it has never left me stranded because I am a maintenance nazi, and I never "push" my setup.
