Easy passenger front axle removal from transmission
GDNF2ET
586
11
Feb 12, 2003
VA Beach, Virginia
The problem with removing the axle is that there is no ridge to pry against..Put an intercooler clamp around the axle hub..Now you can pry against the clamp tensioner with a screwdriver..Popped mine out in seconds !! Tapping the hub with a small hammer while you pry against the clamp will help if its stuck..The pic shows the hub right after it popped out..This was done on an automatic, awd 1g...
