E85 or C16 with meth injection
rr06rs
Supporting Member
421
Apr 25, 2009
Jacksonville, Florida
Just curious what people have experienced when running the same setup. From what I've seen E85 is the better route but I'm just curious about peoples experience using both with meth injection? What allowed for more boost/timing with less knock?
It was found that most people dont understand the full capabilities of e85 yet without going to a tuner. So compounding it with meth, is not needed unless you are planning on running no intercooler and need the extra cooling provided by the meth. E85 naturally burns colder than normal pump 93. So if you want a good fuel, and run a intercooler, stick to just that. Meth isnt needed.
So nobody is running meth w/e85? I would think regardless, it would still push the knock limits further than e85 alone?
