e316g smic
turboedspyder
103
Feb 28, 2007
Shillington, Pennsylvania
right now im only maxing out at 10 lbs because my wires for the wideband were ripped off and i wanna run low boost since i cant see the ratios. but tomorrow ima souder them back together and was wondering what would be a safe amount to run with the stock intercooler for now without heatsoaking it after a few pulls. would 15 be good for now?? after i get ill be a front mount ill run 23, cant wait to see how nice its gonna pull then :hellyeah:
The main thing is not heat soaking it.
I ran 18psi on the track with it but made sure the car sat for a while so it cooled down. But that is also the reason why it blew because I heatsoaked the IC.
just dont run it HARD for a long period.
I dont think that the SMIC would have anything to do with A/F ratios just the air intake temp.
anything under 20 psi .. the stock IC is good for one hard run.... than it takes a while for it too cool down for it to safe to do another run...
ok so ill try 17 and not drive it hard too often. and i was just saying i didnt wanna raise the boost until i get the wideband working because i dont wanna run 17pounds and not knowing if its wayy to rich or wayy to lean.
