donniekak
DSM Wiseman
- 5,758
- 1,136
- Mar 23, 2008
Surprise,
Arizona
Just to let everyone out there on e-85 know. I was having an issue with running lean at high boost high rpm's. I thought it was something i needed to tune out as i recently switched from 1600's down to some rc 1000's. I kept adding fuel with no results. I changed the fuel filter in the engine bay and it didn't really help. I knew there was no way i was maxxing out a 255 on a evo3, but just in case i was ready to put the second pump back in and run 2 again. When i pulled out the pump the sock was completly "gunked", it was sticky to the touch, and i couldn't pump water through it backwards with a garden hose, it was so plugged up. I put the other sock on from my other walbro, and it is going much better now, except for my stupid rich tune.
but like donnie said my DSM is up more then down judging by 199k stock bottom end so it does not sit. Its my daily i probably put more miles in one month then most in a year
