2G Fuel line for e-85 size
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
Anyone know what size hose I need to swap out for e-85? My old rubber lines need to be swapped out. Already have the engine bay fuel lines done, what size is the small emission line on fuel pump hanger? Also the return line has a short rubber line about maybe three inches? And were the fitting gose on to the main feed line to hard line in the middle there’s rubber what size do I need for all the rubber lines. Also inside the fuel hanger do I need to swap out that small hose inside for Submersible Fuel Line? Or I’ll be fine looks like it tee’s off to the return and emission. I’m not running emissions
If you go to Summit Racings website, it will tell you which lines are good for E85 or other alcohol based fuels, you can even narrow your hose type to ethanol compatible in the search engine.
