duggyb's Official Teardown And Rebuild Thread for 4G63T
duggyb
Jul 9, 2008
Regina,
well after discussion in the problem forums i decided to purchase the car and am now going to pull the motor/trans combo out
now since i am a newb to the 4G63T motor here is the place to rattle me with all the things i am doing wrong and help a noob out...if you see me doing something wrong..or missing a part i should be changing/buying/moving.. whatever...PLEASE TELL ME!!!
ok i plan to take as many photo's as possible in hope you guys can notice something i missed.
start....the motor itself(specs-supposed blown headgasket,need many seals,plugs,gaskets...maybe rings)
for now i am pretty much doing a complete head and timing rebuild and also thinking about rings and bearings depending on the conidtion when i get in there.
shopping cart currentley consists of:
PSI-COM_ARP_DSM ARP Headstuds + Cometic Headgasket: 90-99 Mitsubishi Eclipse $ 156.50 (what bore?)
TPL-CGSMI6 Topline Complete Gasket Set : Mitsubishi Eclipse 90-99 $ 119.00
includes:
-(1) Head Gasket
-(2) Water Outlet Gasket
-(1) Valve Cover Gasket
-(4) Spark Plug Tube Seal
-(4) Throttle Body Gaskets
-(1) Exhaust Gas Recirculation Gasket
-(2) Timing Cover Seal
-(16) Intake & Exhaust Valve Stem Seal
-(2) Distributor "O" Ring
-(4) O-ring
-(1) Intake Manifold Gasket
-(1) Exhaust Manifold Gasket
-(1) Thermostat Case Gasket
-(1) Semi-Circular Plug
-(2) Camshaft Seal
Lower Block Set Includes:
-(1) Oil Pan Drain Plug
-(1) Oil Pressure Relief Valve
-(1) Cylinder Block Water Hole Cover
-(1) Timing Cover Seal
-(1) Oil Pan Drain Plug Washer
-(3) Water Pump Gasket
-(1) Oil Pump Seal
-(1) Rear Main Bearing Seal
-(1) Water Pipe "O" Ring
-(1) "O" Ring
-(1) Oil Pan
-(1) Rear Main Bearing Retainer
-(1) Oil Filter Bracket Gasket
-(1) Front Case "O" Ring
-(1) Balance Shaft Seal
-(1) Oil Pipe Seal
-(1) Oil Pump Seal
-(1) Oil Pump "O" Ring
-(1) Timing Cover
-(1) Oil Pressure Relief Valve Plug Seal
PSI-PTESeal Fuel Injector O-Ring Replacement Set $ 12.00
NGK-BPR6ES NGK Copper Spark Plugs BPR6ES: Eclipse 90-99 10.00
MIT-MD972052 OEM Water Pump Assembly : Mitsubishi Eclipse 90-99 $ 133.00
PSI-BSRK Balance Shaft Eliminator Kit : Mitsubishi Eclipse 90-99 $ 46.50
MIT-MD326059 OEM 4G63 Timing Belt : Mitsubishi Eclipse 90-99 $ 69.00
MIT-MD115976 OEM OEM Balancer Tensioner Pulley: Mitsubishi Eclipse 90-94 $ 29.00
MIT-MD131241 OEM Crankshaft Timing Trigger Plate : Mitsubishi Eclipse 90-92 $ 6.12
MIT-MD156604 OEM Timing Belt Idler Pulley : Mitsubishi Eclipse 90-99 $ 35.00
MIT-MD164533 OEM Timing Belt Tensioner Adjuster : Mitsubishi Eclipse 90-92 $ 82.00
PSI-7CMGSK 7CM Turbo to Manifold Gasket : Mitsubishi Eclipse 90-99 $ 12.00
am i missing anything? let me know.(P.s i will add the rings once i find out if i need them.)
here are a few starter pics
i will update as i tear into it more and make further progress...i did not want to go any further yesterday until i picked up the haynes manual which i got today.
THNX
Duggy
Plan for the worst, hope for the best. Even if you dont need to put new rings in right now, its smarter to rebuild the engine now while its apart then do this 6 months or a year from now. That motor is tired and beat and wants a new life.
James :laser::talon:
I would definitly change it all now that the engine is out then have something go bad and have to start over......goood luck
I've purchased a rebuilt shortblock and have a head that was rebuilt a few thousand miles ago and will be assembling the longblock with it, installing all the ancillary stuff too. (I replaced the clutch, clutch hydraulics, updated HLA's, starter recently). I have a Big 16G to go on as well.
This seems like a really thorough parts list. Thanks for putting it all out there! I went to extremepsi's site and found it all, and the prices are low compared to the other places I've looked.
If anyone sees anything missing, please speak up.
(I hope this doesn't seem like a hi-jack - I searched for a thread with a thorough parts list for a rebuild and install and thought this was the best. Nothing like recycling to make the search results more condensed!)
Thanks,
Pete
Pete's V8 Datsun 240Z Pages
