jking29
- 656
- 8
- Jun 7, 2005
Huntsville,
Ohio
Ok, I have an idea that I am not positive will work as I think it will. I am going to be adding a 50-75 shot of nitrous this year and know that I am going to need a bigger fuel pump than my current 190. I want to switch to a Supra or 255 pump, but don't want to spend the $200+ for an Aeromotive fpr and don't really trust the Megan. I have more fabrication skills than money, so my idea is this. I want to take a second stock 1g turbo fpr and make an adapter to use it on the fuel supply to the solenoid for the nitrous system. My understanding is that the reason the 255 over runs the stock fpr is that return orifice is too small to deal with the extra volume. If that is the case then 2 stock fpr's should give enough return capability to be able to deal with the extra flow and not have over run issues. I would Y the return lines together to go into the tank, and since the turbo fpr is boost referenced, it would raise fuel pressure to the nitrous side of the system also to keep correct flow. Is there any issues I might be overlooking? I am looking for concerns and feedback from experienced people, not "just buy an Aeromotive" answers. Thanks!
