And_44
- 835
- 8
- Feb 13, 2010
Marysville,
Washington
Hello,
I've been searching and wanted to clarify that I understand this right.
With DSMlink a Wideband, and an adjustable fuel pressure regulator (afpr) is still needed for tuning above 15psi? As the o2 reading that Link gives is not as accurate and Link doesn't control fuel pressure. And Link can be used for logging as well so a palm isn't needed?
Right now currently at 10psi (stock). Will be getting a MBC to go up to 15psi when the ECU get's back. That alone won't require an afpr, but a wideband would be helpful but not neccesary.
Will be getting either a 190 or 255 Walbro next along with an afpr. Wideband will come with these if not needed before.
Doing Link now because I sent in my newly purchased EPROM to get recapped and cleaned up and thought while it's in get link, kill a few birds with 1 stone should I say.
Mods in my profile are up-to-date as of now, will update when I get more (ie, Link, MBC, ect.) Can't put it in there when I don't have it
Just a recap
Wideband and AFPR are 100% needed after 15psi (that's with larger pump)?
No palm logger needed with Link?
Can I get away without an Wideband under 15psi with Link readings?
Just a recap
