ECMlink DSMlink V2 FP3065 logs
Evil1gDsm
521
Sep 4, 2004
Fox Lake, Illinois
Attached are some logs from driving & pulls.
I'm running a conserative 11.0 AFR, which still seems a bit rich to me since i have a bit of Grey smoke between shifts...motor is solid...Your advise gods?
Thanks,
Dan
What's up with your MDP sensor? It doesn't see boost anywhere during the logs. Also, your coolant temp never exceeds 179 degrees, except for a few seconds during deceleration, so the ECU will never enter learn mode and adjust the trims. How do you know you're running an AFR of 11:1? I don't see a WBO2 input, or do you just not have the gauge wired into the ECU?
Hey Guys,
Yea i didn't have my AEM value correct when i made the pulls. that is fixed, and yes i am running a blow through setup.
I installed my water injection kit & it seems to really help the knock. I'm going to try & get the car tuned on E85 once i get my other fuel pump & post some new logs...sorry for the delay!
attached are some more recent pulls with the water / meth injection.
Thanks,
