ECMlink DSMLink tuning
Post a log. Are you going super rich by any chance? If so, could be a boost leak.
Also, you have a Wally 255 listed under your profile. Is it rewired? Do you have an AFPR?
Check to make sure you have it in captured values first. then all you have to do is put it in displayed values, and you should be able to view it on your logs.
You had airflow captured in your log but the MAF doesn't look like it was connected. Both the MAF and IAT were reading like they were unplugged. It doesn't look like you were capturing the Baro input so I can't tell if all three MAF inputs were dead.
Coolant and intake temps are important. so why are you saying don't mind them? post up an idle log at operating temp as already advised and we'll see if we can help.
