2G DSMchips QuesTions
1999silverGSX
142
Feb 20, 2006
New Castle, Delaware
Well i have been thinking that i might want to go with bigger injectors the 650's when i run the scm5031re . I was thinking more like 750's or 850's. Currently i have SAFC neo and Was looking at dsmchips to run the safc/chip combo . I have a few questions my car is a A/T 99 GSX Currently
Revlimit 7500 ( stock )
Reset Octane
Eliminate Fuel Cut and Air Flow Cap
Converted Factory Boost Gauge
StudderBox - NONE
NLTS - NONE
A/C cut Out
idle 750
injector size - either 750s or 850's
Stock 2g mas
Please hit "ENTER" at end of box!
Please indicate what octane fuel
and fuel pressure you are running
well Im going to be running a 190lph fuel pump most likely 750's , SCM-5031RE , SSAC fmic , Full Exhaust SAFC neo . If anybody could help me pick the best options for my setup on DSMchips i would GREATLY appreciate it
Reset Octane
StudderBox - NONE
NLTS - NONE
A/C cut Out
idle 750
Stock 2g mas
I see your on the east coast so you should be able to run 93 daily and stock fuel pressure is 43 psi so I would use those # if this is a daily driver.
talk to Andy the wiseman on here before purchasing also. He has run over 20 different chips and knows what he is doing. Also I would go with a custom burned a/f ratio along with timing curves and caps.
DSMlink is great, but these chips are pretty amazing. Jeff does a great job with these. Like Jay said try and get a hold of Andy Moraitis hes really good at helping you figure out whats best for your setup. He helped with mine and I have no complaints.
I think the chips are cool and all, but what happens if you decide you need bigger injectors ? You have to buy another 300 dollar chip and sell your's for dirt cheap.
DSMchips can have any of the settings changed for a $20 fee. Not too bad, but it's still wise to get the biggest injectors possible and not worry about it later...
Just send Jeff an email. He is very prompt to respond & is the best person to ask. He was very helpful when I was choosing my chip options.
[email protected]
Sorry for reopening old thread, but anybody know Jeffs personal or any active email adress of him (if its secret, you can DM me) ? I need to connect with him and ask him some things about chip. Or better if he is still active here, he can write me. Thanks
