DSM experts Please Help ! tough one !
vodavi6346
Sep 18, 2004
kissimmee, FL, Florida
okay .. My car leaks oil right after I shut my engine off and I think it might be leakin a bit when the car is running .. Car will not idle right .. boost and rpm will just go up and down nothing over 1k at idle ..
also the car had the head gasket replaced less than 150miles ago ......... and the oil looks like its comming from the head area ...
what could be the problem .. I am thinking the intake manifold where it bolts to the head the gasket could be bad ..
also earlier I shut the car off after driveing it 5miles and i went to start it and it would'nt start so i let it cool down and tried it ...no luck ... i get a jump start because i wared the battery down .. after a good charge and 10secs of cranking it started and i babied it home .. now it won't start .. i hav'nt tried to jump start it yet because i'de wrather get the problem fixed
well i'm calling out the DSM motor heads to see if you have had the problem or know what it might be !
Thanks,
-John
