Does this look right to you?
usmc0651dns
209
Jun 3, 2010
Monticello, Kentucky
I have two things in the 97 GSX that I just bought engine bay that don't seem right to me. I have outlined them in yellow. Thanks.
first one is a water line for your turbo that appears to be blocked off your turbo may not be water cooled so whoever put it on blocked the line
Yea those arent a problem. For the first one, someone may have used the wrong coolant pipe and that fitting was not used.. The other, is a spot to hold the harness down on the IM. Your car may not have that plastic piece around the wiring harness. Not a problem.
Alright thanks guys. I thought maybe on the second one it looks like the hole is tapped all the way into the manifold. I wasn't sure since on the other side there is a vacuum hose that is T'd.
Thanks that helped a lot. I'm having issues after I changed the plugs, wires, and put 850cc injectors in. The car won't start. That helps put my mind at ease about those pics at least.
