Does the Portfueler need the FCD?
All problems have been solved, Thanks guys. Now that all of my quirks have been worked out, it is time for me to break her in.
Please explain what you did to fix your problem for furture readers.
+1...do you plan on telling us how the car magically fixed itself while still making yourself sound like the uber technician hehe.
Wait a minute, WAIT just a minute!! You can't leave us hangin' like that :nono:
Gotta tell us (and the future searchers) what the problem/s was/were.
MB
MB
Okay the biggest thing was, LOL, we wired the tach adapter wrong. You need to wire the red and red/green wire to the BIG black wire coming out of the coil harness.
What else? Ah, yes I have a T3/T4 57 trim hybrid turbo, running a 5 lb spring will OWN your rpm's at WOT, we added the other spring making it a 10 lb spring and it spools all the way up to 7k rpms. These larger turbos have a minimum efficiency.
As I sit now, I took my spring out of the wastegate to run N/A for a bit to break her in, those pistons were pretty but not pretty enough for me to see them again.
Hope that helps Mark.
-Alex
Ok, so you boosted some already I see...ya know, it only takes one time ;)
Luckily, no harm has been done. I have almost 250 miles on the engine so far and it is running great with no leaks, still no wastegate spring.
I think the spring I got with my wastegate is a Homedepot special that got attacked by a can of paint. It is the small blue but that is supposed to be 8lbs, it tapped out at 5lbs, Oh well. Anyone have an extra, or do I have to dish out that $30 bucks?
Not sure what you're tryin to say LOL...
so the question, should we still hook-up a FCD when using the portfueler system.. if we do, then will the stock fuel curve on the portfueler cause us to run too rich during boost.... also can someone repost how to hook-up the water lines for the turbo.....
The reason why you're probly not making any power is because you need the valve seat/ seal. Heres a link to get one.
http://www.extremepsi.com/store/customer/product.php?productid=19940&cat=1142&page=1
Let me know how it works out for you.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
