Do I need to change the gasket if I take off the throttle body elbow?
sbeck
171
May 15, 2010
Hemet, California
Must I replace the gasket if I take off the throttle body elbow? I have never taken one off on a dsm but I know with some other cars the gasket just falls apart or is too compressed to work again if removed.
So the metal 2g gaskets don't hang over into the air stream?
I figured it would since they're for a 52mm tb as opposed to the 60mm 1g...
No, you're correct. The 2G gasket WILL intrude into the air stream and affect flow through the TB. I wouldn't recommend it with a 1G TB. Also, if the gasket is embossed then the ridge might not even end up between the sealing surfaces.
Definately buy new ones. They're cheap enough. I'd buy a few of them if the store has em. Never know when you'll need or want em.
