Diy Beware!!!
boostin97talon
87
May 20, 2002
Oregon, Wisconsin
I can't help but notice the huge number of posts on this site asking for help on topics such as 'I replaced the head gasket or intake gasket or did a 6 bolt swap or replaced my clutch and now "insert problem here" is wrong with my car, HELP!' The #1 HELP that I can give to all of you is to check your own work. If your car ran good before you replaced part X with Super High performance part X, and now your car runs like a$$, 99.9% of the time it has to do with your workmanship, and nothing else. It is very (politely to say) disturbing when someone posts 'I put a head gasket on this car, and now it doesn't run, since, I replaced the coil pack, transistor, injectors, fuel pump, maf, cam sensor, tires, and steering wheel and it still doesn't run!' I swear, you'll see the same guy a week earlier flaming dealer techs or independant shops for 'trying to rip them off and not knowing what they are talking about'. For some reason 'that guy' feels he's saving money by doing the work himself and replacing every part under the hood he could think of to fix his problem, and still not have it fixed.
If you couldn't tell by now, I am an auto tech by trade, and have been for 12 years. Okay, so yeah I'm 30. I feel it too. I worked at a Chrysler/Mitsu dealership for 4 years and have been working at an independant shop for the last 8. Which by the way, if there are any aspiring auto techs out there, if you work at a dealer you will learn some aspects of a specific car and that's it, work at an independant shop (depending on the shop) you will learn all aspects of every car. Example : Every week I'll work on from a 98 Civic to a $50 92 F-150 to a $200k modded 996.
Two DSM examples of customer arrogance come to mind. One is a DSM High Perf enthusiast who had recently installed a FMIC on his car, and then quickly after 'broke his transmission' and wanted us to replace it. It was a 2g FWD. Before I go any further, I must state how adamant this guy was in is 'knowledge of DSMs' toward our service writer. I went to pull the car in noticing that his shifter was broken, which he was aware of and said that the trans was so hard to shift that the shifter broke. After a minute of looking at the car trying to figure out why a shifter would break I found that Einstein, during his FMIC install, had managed to route his lower radiator hose around the back side of the trans shift linkage. Therefore once the operating temp had been reached and pressure was built up in the cooling system, it was nearly impossible to shift into 1st 3rd or reverse, which in turn led to him breaking his shifter. Lucky for him, I cought this early and his repair bill was minimal.
Einstein #2 brought his car to our shop (94 Turbo Talon) claiming he has blown up his engine, and wanted it replaced with a JDM 6 bolt that he bought over the internet. The engine had shown up at the shop so I towed his car in, yanked his engine per his request and after a little screwing around with fitment and placement of parts, got his 'new 6 bolt' in and along he went. Being a curious DSM enthusiast, after the fact I wondered how 'toast' his engine really was and investigated. It turns out the guys timing belt tensioner failed, allowing the belt to skip a few teeth to make the car not run, but not enough to bend any valves. He could have been down the road with a repair bill of a fewhundred dollars, but decided to himself that he knew what was what, and simply stated 'replace my engine with this one', and ended up spending thousands more than what was needed.
That incident is not on me. The sad part is that if he would have brought the car in and said 'The car died on me going down the road, see what happened and if it needs a new engine I want this 6 bolt installed', he would of had the option to spend a few hundred compared to a few thousand on the car.
Point is, if you are over your head in trying to fix your, or someone elses car, taking it to a good shop and telling them the truth about everything you know could and probably will be cheaper than replacing parts that do not need to be replaced. If you are not confident in the shop that your car is at, don't be afraid to take it somewhere else. But remember, the WORST thing you can do if you take your car somewhere because you can't fix it is to say, 'This is what is wrong with my car, this is what I want replced.' Let them figure it out if it is over your head. That is why shops get paid and are in business.
Okay, one more thing. Please, for Christ sake, DO NOT take your car to a 'Tunr'? shop for a no start / drivabilty problem. Although there may be some capable 'Tuna' shops out there, most are some BS shop that some rich kid straight out of high school, whose parents gave hime the money to open up his 'dream shop' because he was able to bolt on an exaust and intake and read a pile of SCC issues and really knew his stuff and was ready to dial your sh*t in.. OK enough.
Final word on my rant. There are definetly some guys on this site that are kings of DSM knowledge, especially when it comes to building a fast car. There are unfortunately an infinte number more teenage to early twenty kids that like to spew any BS that they heard that they think makes them smarter. Choose Wisely.
Good Night Now!!!
Cliffs: He is a mechanic at a shop. He works on anything from a Civic to a Porsche. He doesn't like people who think they are smart telling him what to do, instead of asking him to figure out a problem to help them save money. Best example is a guy who's tensioner broke and he thought he blew his engine. So the guy paid to have a JDM 6 bolt installed. And don't take your car to a 'tuner' shop because more likely then not a kid straight out of highschool owns it and reads too many SCC magazines.
I like SCC....its better than import tuner....I/T is all about effin honda's.
I dont see how they want to build a high compression 4 cylinder that puts out a measly 240horses IF they're lucky...ugh nevermind.
Good Night Now!!!
I agree 100%, but don't judge a DSMer by his age. :cough cough: I'm 21 and for some reason I don't think I fall in the "BS" category. :shhh:
The guy is right. I agree with him %100. Alot of newbs or even members I see posting end up with more problems after they try to fix their own car, then wonder why. If it's ANYTHING over my head, I take it to the shop I've trusted for years. It's just not worth the money to repair what you may have messed up.
Some things you HAVE to leave to the professionals. Otherwise it may mean more work and money for you.
Good post.
Yea, well with that logic no one should try to attempt anything new. Since, well, it would probably be over there head since they didn't have experience. Not be a jackass, but it doesn't take a super genius to work on cars. I applaud people when they try something on their own. If they mess up, lesson learned. I've messed up plenty, but I learn and continue to learn everyday.
Hi,
I believe that everyone who has posted here is correct or mostly correct in what they have said. I feel that if you are going to take on a project you should do as much research and reading up as you can before hand and then have a buddy around who knows what he is doing. I have always felt very lucky for having friends and my father who know there stuff around cars pretty well.
Bill
I believe in first hand experience. I do not make mistakes. I do a ton of research before I take on a new project. I like to look at all aspects before I start so when I encounter a problem, I know a solution.
I'm 20.
Flash I would like to say TY for the cliff notes version.
And I would like to say to the original poster, people live they learn just as everyone says. Noone knows what they are doing in the beginning, from your logic we should bring our car to the mechanic to install in intake, BTW I have seen many people do... bunch of idiots...
BUt there should be a certain learning curve when trying to do something, research blah blah blah, but I dont think you should group everyone in the same category and without trial and error by your logic there would never be those engineers to create those cars that you work on.
i think the bottom line is when you take your car to the shop for repairs, do not try to diagnose it yourself unless you 100% know what is wrong with it. i know we all think we know more than repair shops but sometimes we are wrong, if youre taking a car in for repairs, let them know the symptoms and maybe what you think is wrong, if they agree, then youre on the right road. if they dont, let them do their job and fix what they think is wrong, if that doesnt fix it, then they have more work to do.
+1000. Your exactly right.
Definately don't judge a DSM'er by his age.- 16
Sometimes the best way to learn is first hand experience. If you make mistakes you fix them.
You have a 97 gs-t and you're 16?!!? Lucky man.
17, still no DSM... hahaha. But I am the youngest kid with a collector car I know.
BUT.......i know for a fact it was my muffler bearings that went out! I mean what else could cause a no-start! now the mechanic says its my battery. I just said yeah whatever. don't install the muffler bearings then, who needs the vtec anyways. ROFL
Yeah. I bought the car when I was 15 started lightly modding it within the first month I had it. The majority was just cleaning the engine bay, interior, and exterior. When I bought it, it had 53,000 original miles. It now has 55,000 original miles. Its nice when you work for something and it pays off. I have done all my own work and have done my homework on every single project BEFORE I executed. Nothing too big, but I have done everything from the brakes and struts to the exhaust and rebuilding the throttle body. Like I said, nothing too big, but something as simple as rebuilding that throttle body was a little nerve-racking with all the small details and things. I think it's all about how you go about doing things, doing your homework, before a project.
I am doing that with my Cadillac, and soon to be DSM... Props to you for not having mommy and daddy hand you everything. I'm in the same boat and wouldn't have it any other way. :thumb:
I wish they would have bought me my car. haha- Would have a lot more money to spend on modding it. But, in the end it just more rewarding seeing it sit there and knowing that you paid for it and it 100% yours.
Had my first dsm when i was 15,almost 16 . Now I'm on number 7 and 19
Unless that mechanic of course goes and tried to strip your cylinder head by cross threading the plugs to hit you up with an estimate of 3500$:confused:
These cars HAVE to be taken to specialists, not mechanics.
then said mechanic needs to foot 3500$ bill because it wasnt that way when you brought it to him was it? please tell me you did not pay 3500$ for their #### up?
  • Wanted 6 bolt NT water pipe
    • chrisman287
