difference in 4g63 from auto than 5spd?
Thats incorrect. A 1g auto has 390cc injectors vs 450cc injectors on the 5 speed. The ecu is also different. A 2g auto and 2g 5speed both have the same injectors and the block is exactly the same.
I do believe that is what kimba was stating. dont forget the cams and turbo. The ecu's are the same amongst 5-speed and autos.
1g fuel pressure regulators are different from the auto to 5-speed. I had to change mine out when I added 450 injectors and manual ecu. Different flow rates.
As far as the 2g is concerned,just the auto and 5-speed are the differences as has already been stated.
1G autos came with 390cc injectors and the 13G turbo stock. They had 180hp from the factory. Other than that and a higher fuel pressure(42psi?) from a different fuel pressure regulator, everything else is the same engine wise. With a 14B, and 450s, an auto will be about the same, speed wise.
And yeah, the 2gs I think are the same, engine wise when it comes to auto vs. manual. Both have T25 and same injectors.
