95 Eprom ECU from an auto in a 5spd
I have an eprom ecu in my 1g auto from a 5 spd. All I did was plug it in. There's no difference in auto ecu's and 5 spd ecu's. The only difference is that there is a TCU unit inside of auto's. They're right behind the ecu. You should be fine, just plug it right in.
It will work fine. The autos have the extra computer (the TCU) to run the tranny solenoids.
Also, think of it like this, all 2gs have 450cc injectors so the maps must be the same/similar. (Im 99% sure they are the same ECU)
That is simply not true, 1G auto comes with 390cc injectors.
2G auto and MT ECUs are identical.
