did i bend my valves
killerclown1984
48
Sep 13, 2008
greenfield park, New York
im replacing the timeing belt and balance shaft belt on my motor i brought the motor to tdc and cut the belt then i replaced the balance shaft belt and heres where i messed up i spun the crank with out the time belt on did i bend some valves
Most likely no, you didn't bend any valves. Just make sure you have the timing correct before you try to start it again cause that will bend your valves real quick.
