Diagnosing my 6 bolt built.
Cesar
519
May 24, 2003
Titusville, Florida
my block
6 bolt n't block
polished crank
acl bearings?
manhley rods and pistons (i think 30 over)
balance shafts removed. stubby shaft used.
line bore and hone with arp stus
arp head studs.
mitsu head gasket.
Here's the issue
under high rpm and high load there is a wobbling (maybe a thudding sound would descrinbed better). usually on the highway, passing. ( i do that a lot)
other than that, the motor runs and sounds awesome.
now my machinist ruled out the out of balance of the rotating assembly because it is intermittent.
I have already replaced the harmonic dampner with one I had lying around, with no effect.
I suspect the tensioner is going, or the stubby shaft is dancing around. most likely the tensioner.
any thoughts??
