diambo4life
- 1,904
- 900
- Apr 18, 2002
Edmond,
Oklahoma
Damn Ty, now that's the kind of knock that can hurt stock parts. So you know, it works like this:
7 counts = timing held
10 counts = 1 degree of timing retard
13 counts = 2 degrees of retard, etc, etc up to 43
Basically every 3 counts pulls 1 degree above 7 counts.
At 5 degrees of knock retard you had ~22 counts of knock. I'd upsize the injectors and fuel pump to make sure you're not starving the motor at the rail but I know the AFC can't be helping. Then again with a better 60', your car is an 11.50 waiting to happen. Damn good on pump gas if you ask me.
Low 10's for an AFR is pretty rich considering that you have methanol. I'd try at least 11-11.5:1 and see how much she picks up. I'll bet it's pretty significant since low 10's is hardly above the stock ECU's target.
That is incorrect and plain false. If you get 1 degree of knock retard, your timing advance gets pulled back ONE degree.
0.35 degrees of knock retard = 1 knock count.
5 degrees of KR = 14.3 counts of knock.
3 degrees of KR = 8.6 counts " " " " .
1 deg of KR is nothing. I personally tune mine for 2 deg of KR and I'm conservative. Most people on the Link forums like 2-3 degrees of KR.
