datalogger
1G9S9T7
104
Dec 11, 2011
Crossville, Tennessee
I was doing some research on dataloggers and all I found were either for 1g cars or just where to buy. I want to see what everyone else is using and what they think of it. I can't afford dsmlink yet so I am looking for a cheaper alternative until I can. A lot of problems I had with my car, upon searching, I found answers saying to use a datalogger or "this is what my loggers said" etc. The rre instructions say to use a datalogger when setting base timing so with that being said, I am going to invest in one. What do all of you dsm'ers use? Well the 2g guys anyway....
I read some on evoscan and thought about buying it. I just didn't know if there might be something better for cheaper or something better but a few dollars more.. I couldn't really find any reviews.
Evo scan is going to be your best bet... . I use it daily and it work great. Your car you can directly swap in a 98-99 ecu and wire in the flash connector(one wire) not present on 97's and have a tuning solution as well if you spend a bit more on more expensive cable. (though it is a bit steep learning curve for some)
You can Use this with Evoscan Click ->> Here or some people have got the Cheap Ebay VAG cable like Click->> This to work as well.
There also is ODB II Blue tooth adapters that work with Torque a Logging App for phones
DSMChips.com | DSM ECU Chips Enchanced by Keydiver
I was thinking about this right here for 50. I'm not too worried about making tune changes yet, more like I need something to log what's up under the hood. I seen instances where it says a datalogger can help adjust tps, biss, base timing etc.. I want something like that. Will this be what I can use? at least until dsmlink...
Might have a hard time ordering from Jeff... .
See this from his home page.
Your best best is one of the 2 links I posted above... .
I looked at that first link, the one for 57, now if I get that one, does it have everything i need or is there anything else I need with it?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
