Datalogger
Usatuff
469
7
Sep 12, 2010
New Windsor, New York
I am making my own cable for the logger but will my PDA work? It's a Dell Axim X5. Thanks
Will my PDA work? It's a Dell Axim X5.
I'm not aware that anyone has ported MMCd to WINCE or if there is other Mitsubishi datalogging software that has.
Does the Dell have a serial port that will run at 1952 bps? For a 1G that's usually the deal breaking issue.
Yea I have about 20 different tabs opened up on Google Chrome haha. I've come to a conclusion that I'm gonna make the wire, with 2 and 3 pins switched (for PC), And I can get a usb to DB9 connector and see how it works out. Total cost $4
Alright new plan, I haven't been able to make the cable yet because of lack of time and I don't remember where everything is. So on a basic USB cable there are 5 wires. Red, White, Green, and Black. Red = +5 VDC, White = Data -, Green Data +, and Black = Ground. The pins needed on the DB9 are pins P2, P3, and P5. Pin2= Receive Data (+), Pin3= Transmit Data (-), and Pin5= Ground. Does anyone else see this not working? I mean there is a DB9 to USB adapter for $2. I' not cheap but if I already have the parts here, why leave the house?
Are you seriously suggesting you think you can make a USB to RS-232 serial adapter just by swapping the USB wires around?
no I was simply suggesting using a USB instead of DB9? I haven't messed with electronics/computers in awhile but after looking at the adapter actually made I can see some board inside of the protective gel.
Yes, there is actually quite a bit of logic in the IC that converts the USB serial protocol into something else and drivers for the host. There are USB to our OBD I and OBD II datalogger cables that don't require a serial port. The new ones that ECMTuning sell and include in their V3 kits are one example.
One thing to keep in mind is that a lot of non-computer devices are slave USB not host USB, they are designed to connect to a host using USB not support attaching USB devices to them, most PDA's are like that. The other is that non-standard datarate the 1G ECU uses I mentioned above. So far it only seems like the FTDI chips support it so if you were to build a USB logger cable using one would be a good place to start.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
