datalogger
nmarcy
45
Sep 1, 2011
River Grove, Illinois
I logged for the first time yesterday,. i would post it but i am still in the process of figuring out how to upload it to the computer. my biggest question is can i install a 2g maf with 560s or will i run to lean. On stock injectors and stock boost i am reading 93.9% on low. and 88-89 on medium and high. I know i am running a little rich, but will adding the 560s and 2gmaf be okay. i am planning on installing them soon and then logging again to check it out, but just wanted to double check before i install and log and run extremely rich or lean. sorry for the long post.
What do you have to adjust the fuel trims with?Safc dsmlink or are you just running a logger?
That is with 550. I have 560s. I am waiting to pick up a safc from a local person as soon as I find the right price and have the money. i was Going to try the 2g maf with 560s and see how it was and then adjust with safc but I'm going to be safe and wait till I get safc then install everything at the same time.
I didn't see this anywhere on your profile, but make sure you have a wideband.Also if you are reading from the stock boost gauge it just estimates boost pressure so get a mechanical boost gauge too.
yeah i need to update my profile. im waiting on a wideband. but i do have a boost gauge.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
