1G dash lights quit working
Boosted DSM 32
681
3
Aug 21, 2011
McDonald, Ohio
I was hooking my boost gauge back up in my center console ( i have the gauge right below the radio) and when i was wiring it back up i heard a small pop and now the speedo lights dont work the check engine and all the other lights still work just not the actual gauge lights or the hvac lights as well only the green button on the ac button work now.. i checked all the fuses and there all fine and all my lights outside the car work still
I have 3 speedos and they all do the exact same thing? is something not wired right or is there a fuse somewhere else that could be bad
im not sure if there is a relay for it but while wireing the gauge up it could be possible that some power wire coulda got grounded and maybe shorted and burned a wire under the dash. Dis it smell like frying wire when this happened?
No i just heard a very quiet pop when i wired the boost gauge up is it possible that something is still wired wrong and because of that its not letting the dash light up?
Sounds like a dimmer switch issue, find a used one and see if that help, i had the same problem fixed with a dimmer switch.
Ok cool i might get into it this weekend if i find some time to just hangout and work on it.. im not really in a big rush to get it fixed when im driving i just cruise so im not worried about getting pulled over
