1G Auto door locks, radio, and dome light quit working
stroh
84
5
Oct 17, 2002
Freeport, Illinois
This is a 92 talon. I have checked all the fuses and everything seems fine. Is there a relay I should be checking? I have looked at the wiring diagram and it seems that there is a relay under the dash that works the power locks, dome light and the radio. Is this the one I should be looking at? I believe it's listed as C-34x. Not really sure. Thanks for any help
I had the same thing happen to mine. I believe that the "room" fuse wasn't making a good connection in the fuse block. I remember that I pulled the fuse to check it and it was still good so I was pretty confused as well. I had to shim the fuse with some thin metal to make the connection and I haven't had any issues since. I hope that this helps...
First I checked the audio circuit. Seems like fuse #6 (15amp) would be my first place to look, in the interior fuse box.
As well as #4 and #19 (both 10amp). They all have something to do with the radio working, and one or two interact with the door locks as well.
Then the dome light circuit, utilizes #19 and #18.
The power door locks utilize #19 and #6.
So 2 of the things not working use both #19 and #6, all 3 use #19.
Now that I wrote all that, check fuse #19 first.
I have checked all fuses and everything is good. :idontknow:
Having similar issues no dome, radio. Door locks swapped body harness out. All fuses have power, any ideas I'm stumped.
Did you ever figure this out?
I just did some wire work and now I'm in the same boat.
I had a short, found it, and removed a remote start that I didn't know the car had. I believe that is where my issue is rooted, but your solution may be mine.
