** Cyclone Or ECI Multi **
Status
Not open for further replies.
sakrafice
217
May 28, 2003
Sumpter, Michigan
Alright well im not to sure what that things called, so imma call it the intake, now ive seen diffrent ones on diffrent cars, i curently have a cyclone motor and a eci multi motor.... which is the better one ? like the intake not motor.... because im building up a motor and dont know witch one to go with.... but it also looks like the wiring is diffrent as well.
Also i got a 6bolt block and a 7bolt head; do i just gotta put bigger studs in or what ? And am i going to run into anymore problems :confused:
Im sure ill find something else dumb to ask tomorrow.
Well usually, the cyclone motors are JDM's. The ECU MULTI are found on the USDM models. As of power the cyclone intake setup has dual runners, which will allow for more power. Swaping it into a USDM car is possible but you need to modify the vacume setup. I belive there is a FAQ somewhere on this. I currently have a JDM motor with the ECU MULTI USDM intake. I am currently considering bolting the Cyclone setup on or getting an intake setup from magnus. Um... as for your 6 bolt, 7 bolt problem... im not really sure but i would probobly want to go all 6 bolt motor stuff rather then have a mix.....
Hope this helped a bit.
G
:dsm: :talon:
Status
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
