CX Racing FPR
aguiga
130
4
Dec 2, 2009
Texas
is the Cx Racing adjustable fuel pressure regulator the same as aeromotive with just a lower quality diaphram??
I need any input on this product. if so can i just replace the diaphram with an aeromotive one and be as reliable as aeromotive?
jim: Do you lose pressure overnight or is it atleast at 20-30psi when you check it in the morning?
For the first6 months mine was always at around 25+psi even after sitting for 4 days. It just kept getting worse.
Unfortunetly it bleeds out after a few hrs. But i have read that this is common with most aftermarket units. Even with 0 pressure my car still fires right up without a hiccup. I could use link to turn the fuel pump on with the key but i really dont want to use that option.
Well thats when i started noticing a problem personally. Car would fire up fast but then it took longer and longer to start. Then i checked pressure and it dropped overnight. IDK, i may have another problem. Its worth a shot to replace it, not much money and besides the only problem it has right now is the time it takes to fire up. SO its not exactly critical. Weird that it still holds pressure at 30+psi of boost....
  • Wanted 6 bolt NT water pipe
    • chrisman287
