Cutting out
Hotmodder
Feb 21, 2008
Leavenworth, Kansas
In the morning it will start up fine, no check engine light on nothing, if you slowly push the throttle, u can make it to redline, but if you floor it, my check engine light comes on instantly and you basically get whiplash. It cuts out, if you keep holding it down it will kick in again then cut out, the boost gauge goes back to 0 every time it cuts out. Im only pushing 12 psi and everything is BONE stock. It has to be something electrical, as in a sensor. I was thinking maybe MAS? But I'm not sure, tell me what you think.
I know this is way old but i had the same symptoms in a pretty wierd problem i had recently, have you changed your computer for any reason lately? (if its not fixed yet):dsm:
It sounds like you have a boost leak, very common problem. Make one of these - IC Pipe Tester - and do the test, 95% of the time that's what it is.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
