WisconsinMonSTAR
- 129
- 30
- Apr 20, 2014
Kenosha,
Wisconsin
Hey all, just have a little ordeal that I need a solution for.
As we all know, the stock 2g plastic bypass valve is trash. So I replaced mine with an Evo MR bypass valve, because it was a direct swap, and can hold a pretty good amount of boost. I like the way this valve both sounds and performs; so I would like to use this one for the remainder of my build, which will not be seeing boost levels over 25 psi.
The issue I am facing now, is that I ordered a nice ETS 7" intercooler with piping kit used off of another member (who gave me an awesome deal, btw) which included an upper IC pipe with both a 1g flange and bov. The bov looks pretty new, and doesnt look like it has been modified.
The question is: how can I use the Evo MR bypass valve with the current piping, while at the same time retaining the flange for the 1g valve.
Reasoning behind wanting to retain the 1g flange is because I would like to have the option to run the 1g valve in the case that my MR valve begins to fail.
Is there some sort of adapter available that I can bolt onto the 1g flange, and then clamp my Evo valve in?
I can upload photos if needed.
Thanks!
Thanks!
