Curious about compression ratio.
DSMsamurai666
89
Feb 9, 2009
Macomb, Michigan
How do you choose a compression ratio when you buy pistons? I fully understand what compression ratio is and that most cars are 10:1, but lets say I hypothetically was building a high performance motor that I wanted to produce like 5 or 6 hundred + horse. Would I want a higher ratio? Also, I'm sure it also depends on boost, but when does the compression ratio begin to induce knocking on pump gas?
I was checking out the brian crower stroker kits and day dreaming about building my GSX.
Well for a street driven car you wouldnt want a high compression. For a car that sees e85 or something of the sort then you can take advantage of the higher compression but for the most part stick with a low compression for high horsepower. Boost can induce knock at almost any amount, it just depends on a number of factors.
Detonation kills engines not compression, you can make a 10:1 DD engine but it will take a cold plug due to the high compressoin having a faster burn rate and E85 will be a big plus, but idea I like a 8.5:1 piston for DD duties.
Yeah 10:1 on pump gas will keep your boost and timing down very low. If you plan on running e85 or race gas, you can take advantage of a more aggressive tune. For a dd, i wouldn't really go any higher than 9:1 so youre still fine with pump. The higher compression will give better off boost response and spoolup too.
