cupple things wrong with my car help with what you can. eagle talon tsi awd 1991
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
1. grinding sound when i try to start moving in 1st or reverse. (only sometimes) kinda like teeth are almost grabbing the gear. and the stick does not feel like its in gear befor it does it.
2. steering wheel shakes when im stoped and i turn the wheel just a little bit. (also if im not turning the wheel i can feel it only on my break pedal.
3. speakers all in frunt will not work i pulled out the radio and messed around with them for a bit. maby all the frount speakers went out?
:talon::talon:
1. check clutch hydraulics, master slave and lines to make sure none are leaking, check the master under the dash.
2. have all the suspension bushings, motor mounts and rack bushings checked
3. were already working on
Easyest way to diagnose if a clutch is slipping is to get on highway put it in 5th and go wot, When boost hits you will know if the clutch is slipping.
Sounds like syncro wear to me but I am no transmission expert.
