Devilsfutbol17
- 407
- 48
- Jul 27, 2007
Bellingham,
Washington
I put on an HX-35 and some DKS 272s and now I can't get my car to idle. I put the timing belt on correctly and just verified that my cams are on lined up properly at TDC. I can get it to idle, but its rough as hell. As soon as I ground the timing connector to check my base timing, it starts to and eventually dies. I can start the car with the timing connector grounded but it dies after 10 seconds.
WOT is beautiful, no knock and pulls smooth. Cruise is just as great, wideband stays right around 14.7 and it drives smooth.
I did a boost leak test and didn't find any leaks. Attached is an idle log. Any help is appreciated.
