ECMlink Dies on speed density but runs perfect on maf?
a7xinsane
51
5
Oct 5, 2013
clarence, Pennsylvania
Hey guys! Have a conundrum I cant seem to figure out. I just installed speed density plug and play bundle from ecmtuning and the car starts, idles really high (2500+rpm) for 10-15 seconds then slowly dies out... Giving throttle immediately kills it. Plugged the 2g maf back in and it runs and idles fine around 800rpm and .23-.25 gm/rev I have my omni 4 bar running directly off of throttle body P port. Ive tried various other locations as well and they all seem to do the same thing. IAT is on throttle body elbow right before the bend in the tube. Have my map reading off factory baro and iat running off intake temp. Ive tried messing with the ve table a bit but I dont want to mess with it too much as the stock should get me running. Seems to die Just as soon as the O2 starts cycling. Ive followed the ecmlink eiki speed density setup to a T about 3 different times now. Just a stock 6 bolt with a 16G, fmic, and 560 injectors. Please and thank you in advance for the help guys.
Can you post a log, even if it is very short so we can look at your settings?
Sorry for the delay. I will try to post up a log of both the maf on startup and speed density on startup tonight. Didnt want to screw with the tune last night as I needed to drive it. Thank you guys!
