Crower stage 2 turbo grind cams
bmxunderground
217
4
Dec 11, 2007
Bowling Green, Kentucky
Has anyone here running the crower 2 turbogrinds experienced any oddities in vibration throughout the RPM band? Here's what I'm getting at.
There is a very odd but distinct vibration at about 3k to 4k. I will try and articulate the sound being made by this vibration. driving with knobby dirt tires is all I can come up with. It makes the noise with no load and less with load.
I cant find anything rubbing, the clutch being pressed or not doesn't make a difference. It's bugging me, because in all of my experience I've never had this type noise! There doesn't seem to be anything contacting anything, almost like the combustion alone is creating the noise. But then again, I don't think I've heard anything from peoples videos other than loping idle so I'm concerned.
chime in if you have any information that could help me out. I'll keep inspecting as time permits tomorrow evening.
You have isolated this noise to that it is from your cam swap? I assume there was no vibration prior to the cams? And immediately after the sound surfaced? There were no other modifications performed at the same time as the cams?
well I added cams, cam gears, and different valve springs and retainers. My old set up though was out of time bad so I don't have a good marker to go by.
If you guys are running these cams and have nothing but smooth acceleration then I'll have to do some looking around... its killin me though! I'll try to catch it on video. In the mean time, drop me some info.
I was concerned about valve clearance, but I'm sure I would def have more problems than vibration if that were the case.
Rest assured that unless you did something really radical (say took off .070 on the head, LOL), you'll have no clearance problem with these cams and 8.8 pistons; or 9.6 pistons; or 10.5 pistons for that matter.
MB
I'll have more time Monday and Tuesday to both test things and take some video. I'll post my findings
few pics to pass the time
<a href="http://s216.photobucket.com/albums/cc154/bmxunderground/?action=view&amp;current=IMG_3015.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc154/bmxunderground/IMG_3015.jpg" border="0" alt="Photobucket"></a>
<a href="http://s216.photobucket.com/albums/cc154/bmxunderground/?action=view&amp;current=IMG_2076.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc154/bmxunderground/IMG_2076.jpg" border="0" alt="Photobucket"></a>
<a href="http://s216.photobucket.com/albums/cc154/bmxunderground/Sliver%20Eclipse/?action=view&amp;current=IMG_2048.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc154/bmxunderground/Sliver%20Eclipse/IMG_2048.jpg" border="0" alt="Photobucket"></a>
After talking to a few friends from local shops, people believe that it is my clutch setup that is causing the vibration.
I took off the aluminum flywheel on this last build since my pressure plate was toast, and put back on the starter flex plate deal and a modular centerforce clutch. Other than those crazy little weights they have on the pressure plate, could there be a possibility of the clutch unit itself to being misaligned?
I'm actively working this issue out, actually have a SPEC stage 4 clutch on the way from another user here. But any prior experience any of you have had with this issue would be of interest to me for sure.
OMG @ your car.. That is the definition of a hawt setup man.
Thanks, but I would love to be driving it right now! haha. I've actually got a guy trying to trade me an RX8 for it this week after I get it back together.
People saw me killing races at 18psi recently and they want it for themselves. I just need it to be user friendly and trouble free when I let it go.
I hope later in the year to pick up an all black GSX. never owned a 4G63 car yet, owned over 30 420a's however.
To be back on track however; anyone with info on my issue please post!
You might resolved it already but are you sure your balance shafts are in phase with the rest. Remember that having it on mark doesn't mean it's set right.
I forgot to end this thread. I found out that the Centerforce clutch I had installed did not self center like the OEM clutch. I had removed the aluminum lightweight flywheel since the Centerforce is modular like the OEM design. At any rate, the button on the back had play where it fit inside the crankshaft. Being off center made a hell of a vibration.
Since then, the clutch was pulled, new lightweight flywheel reinstalled and the car is back on the street dominating.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
