ECMlink Critique my tune!
Justin Lauscher
221
34
Aug 18, 2015
Escanaba, Michigan
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks?
no leaks
2). Verified mechanical timing?
yessir
3). Verified base timing?
yessir
4). Ignition system
COP or Stock Coil:stock
Wire brand and Age:NGK, 3 weeks
Spark Plug brand, type and Gap: NGK BR8ES .020
5). Motor health (Compression Test)
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
6). Performed basic throttle body adjustments?
Idle Switch:simulated
Throttle Cable:
TPS:good to go
BISS:simulated
7). Compression ratio
stock 1g 6 bolt
8). Any known bad sensors or brittle wiring?
9). Any DTC/CEL codes?
nah
10). Electrical system
Car off (not running):
Car running:
11). Base fuel pressure and injector values
Base Fuel Pressure:41
Injector Size (cc/min):pTE 840's
12). Properly calibrated and configured wideband sensor
Sensor Brand:Bosh wideband sensor, MTX-L
Calibration Date: 3 weeks ago
13). Type of fuel
Type:92
Percent of Ethanol:~10%
14). Watched ECMlink how-to videos? yessir
Please critique my tune. I'm currently battling some boost creep and trying to dial in the wbfactor is kind of a pain in the ass with the afr changing from the knock. please flame away! i have not messed with the timing tables really at all, just the sliders so far.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
