ECMlink Critique my tune plz
TasosEclipse
129
4
Oct 20, 2016
Thiva, Europe
Do you have any suggestions on my tune the car is with sd tune 1000cc id injectors, gtx3071r, 2.3 stroker, cop, methanol injection and I think I forget something.
There is no datalog to look at.
You are pulling timing sliders down along with having a timing table that's double digit negative values. I don't understand the thinking behind that at all.
Based on your loadscale value, I assume you are .020 bore over? If so, very very nice work there and I am impressed.
If you can log VE, Linear WB, and MAP, save a log ".elg" file and upload it, same as you did your other files. The settings and DA parts will be saved in the log - so you don't need to collect them seperately.
If you want more than a setup review, Log a 3rd gear pull from 1900-7100rpm (or as high as you can get without knock)
