ECMlink Critique my SD!
TSITurbo95
18
Oct 26, 2009
Ohio, Ohio
So I am in the process of tuning on SD, mods in sig. How does everything look?
See values that high in the SD tables tells me your global % needs to be adjusted, and then scale the SD table for it.
You could also use a bit of smoothing as I see jumps of over 10 from cell to cell.
You can also tell it's off a bit when comparing the AFRatioEst and wideband lines.
I'd also recommend using just the DA tables for adjustments and not the sliders (i.e timing sliders).
Overall it looks fairly well as long as you smooth it out a bit and adjust global to be able to scale down the SD table. But the lines are close and you're on the right path.
Ill smooth a bit more and get back on that. As for the injectors, I dialed them in where the car likes it. Any lower and I have high cells.
As for the timing sliders, I am using them as a temporary adjustment, as I am learning what the car likes, once I find it, I will use the DA table to adjust it.
Tried fiddling with that, but it does not work well with office 2010 :/. Anywho, ill adjust the cells a bit more and lower the timing 2 more degree's to see if I can get rid of that knock. Then add some more boost/meth hopefully.
But isn't that technically a "band-aid" fix to lower sd cells? I mean I don't think my cell's are terribly high personally.
Also to add on the cell smoothing, are you talking about the cells used for cruising? They have to be that low in order to get the combinedft in close to 0, so should I just work around that, or?
Judging from your VE table and the relatively low amount of AFR error, I would say you definitely have something incorrect with either the fuel values, or an incorrect MAP sensor input.
Based on the low VE values at low loads/RPM, and the high values at higher loads/RPM, I would say both your global fuel value and injector deadtimes need some more work.
I have a set of new injectors on the way, and will play with it a bit more with them and repost a new log.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
