Crimped hard fuel line at pump...
Mitsu90GSX
50
Sep 3, 2004
York, Pennsylvania
So i'm tryin to pull my old fuel pump to replace it w/ my new walbro 255. Tryin to break that fitting loose is a real PITA! I ended up twisting the hard line that comes up from the tank and crimping it completely shut. :mad: So its off to the junkyard to find a whole new assembly. My question is, can i use a pump assembly out of a non-turbo? will the plugs be the same? will my walbro still fit on the gs assembly? is the hard line the same size?
This is the assembly i'm talking about for any who don't know, (from vfaq)...
I believe that the pumps on NT are in a completely different spot then the AWD so the set up is probably different.
